My cr3 images will not show the correct orientation, portraits are turned on their side. I had read that this was supposed to be fixed in the latest update (0.96.5) but I have updated and it is still not working
Within xnview the image thumbnails are the incorrect orientation, full size they are also incorrect orientation. the thumbnails in my "finder" on mac are the correct orientation if that matters.
I have made sure "rotate images according to exif data" and "use embedded thumbnail" are checkmarked in settings, I have rebuilt the thumbnails, I have restarted the computer after the update.
I am at a loss, is this not fixed or is there something I am missing?
cr3 images from eos R incorrect orientation
Norberstudios
