Is it possible to customize the context menu one sees when right-clicking a thumbnail ?
If it is not possible, I have made the suggestion that it be made so.
Thanks for reading and all help is appreciated.
Right-click Context Menu ???
Rick
Re: Right-click Context Menu ???
I have not seen a way to do that but yoou CAN build toolbars to keep your favorite tools hand
What would you like to accomplish?
Rick
Rick
BuckSkin
I would like to have the option to remove all but two choices from the right-click menu = Edit IPTC and Edit Comment
Of course, such a modification would need to be reversible to default.
I have those options on the toolbar, but that takes a long mouse maneuver back and forth with every image; the right-click menu does not require so much chasing around.
