Search source empty after Image Overview
MoonTower
Post by MoonTower »
if I e.g. select drive D: and use the search function (STRG+F3) to search for images and then display them in the image overview, everything is fine. But if I want to find something new again (STRG+F3), the source is empty, so drive D: etc. is no longer displayed in the search function. As a result, nothing is found. You have to select a source again first. It would be nice if Xnview would remember the last source. Thanks and best regards
dinamikler
Re: Search source empty after Image Overview
Post by dinamikler »
+1
