I use xnview to manage all my pictures - and I like it very much.
Therefore I have written an instruction (in german) for those who use webspace for their ebay listings - using xnview to manage the pictures.
For this purpose I missed a small option in "create filelist" (Dateiliste erstellen):
if you like to use this list as table of contents of your webspace you have to replace the backslash from PC with /
the problem --> http://terrenal.de/help/webspace.php#einfuegen
An option to replace the backslash would be useful to copy the path for correct URL from the filelist without an extra step using a texteditor.
Is it possible to add this option?
replace backslash in "create filelist"
terrenal
Re: replace backslash in "create filelist"
Yes i'll add itterrenal wrote:Hi,
