0.96.5 - file copy prevent drag & drop operations in other programs
masterjp
Post by masterjp »
I used XnViewMP 0.96.5 64bit under Windows 10 and copied picture folders (around 15 GB data) from harddisk to usb stick with dag & drop.
The copy process works correctly, but I can not use drag & drop functions in other programs. Why is it blocked?
Re: 0.96.5 - file copy prevent drag & drop operations in other programs
do you have same issue with 0.97.0?
