[0.96.5] Saving Capture issue 1 (XnviewMP no tabs mode) [Solved]
Gwenael Q.
Post by Gwenael Q. »
When using XnviewMP without tabs (View > Tab > show unchecked) Capture tool is difficult and annoying to use
After having made a capture (Tool > Capture...), the new image have to be saved (even if user don't want it) to get rid of it.
The "no" or "cancel" button are of no use. If they are displayed they should do what they are supposed to do....
Workaround : Use Capture tool with tabs activated :-)
XnViewMP 0.96.5 - 64 bit on Windows 8.1 64bit
Thank you for listening
Updated description and title (18/09/2020)
Re: [0.96.5] Saving Capture issue 1 (XnviewMP no tabs mode)
when you close the view, you can use 'no' when you have the question for saving
Gwenael Q.
Hello Pierre,
Oops !... I don't understand why today everything seems to work as expected...
Did some tests and all is behaving logically.
I didn't make tests on the same version than previously but, anyway, please consider this issue solved !
