[0.96.5] Saving Capture issue 2 (XnviewMP no tabs mode)
Gwenael Q.
Post by Gwenael Q. »
When using XnviewMP without tabs (View > Tab > show unchecked) :
After having made a capture (Tool > Capture...) from an image in xnviewmp in view mode, then saved the captured image, the viewed folder is now the folder where the image was saved and no more the initial folder from where image was captured.
Saving an image should not change the folder browsed.
Thank you for listening
XnViewMP 0.96.5 - 64 bit on Windows 8.1 64bit
Updated description and title on 18/09/2020
Re: [0.96.5] Saving Capture issue 2 (XnviewMP no tabs mode)
please check Settings>General>File operations - For save as...
Gwenael Q.
Hello Pierre,
Thank you for the tip but's that is not the real problem. In fact, I think it is me that misunderstood something.
If I save a captured image in a folder, without closing this image after, then previous/next commands will then display others images of this same folder.
If I want to browse the initial folder from where I did my capture, I have to close the saved capture.
So, sorry, it seems that there were no real issue... Please consider this discussion solved.
