in version 1.74 i was able to move the entire cropped area with my
left mouse button. in 1.80 this ability is missing. the cursor is now
the zoom in ??
also the refresh button in the browser is gone?
appreciate any replies.
tom
crop function
Re: crop function
The topic "How to move selection area?" will answer your question.tomcom wrote:in version 1.74 i was able to move the entire cropped area with my
the zoom in ??
Refresh button has moved from the large toolbar to the small toolbar (above the file list). You should find it there easily.tomcom wrote:also the refresh button in the browser is gone?
tom
Reset---
- Go to Options (button or Tools menu) >> View >> Keyboard / Mouse,
and reset the options you need from the dropdown lists…
- I am using the left-click here to adjust ¦change the "crop" selection with 1.80.3
refresh button in browser
i solved the crop/cursor problem with your help,
thankyou!
but the refresh button is Not in the small toolbar above the files???
the only buttons are:
up one level/new folder/rename/delete/favorites
i don't even see in the options/toolbar where there is any choice for a
refresh button??
could it hae anything to do with the fact i use the classic skin?
thanks again for any help with this.
tom
thankyou!
refresh button??
tom
Re: refresh button in browser
Yes, the Classic skin does not have a small refresh button, this is why you don't have it. Not sure whether Pierre plans to enhance the Classic skin.tomcom wrote:i solved the crop/cursor problem with your help,
thankyou!
refresh button??
refresh button in classic skin
thankyou for the reply
tom
tom
