Thanks
Does it work with my NAS in the Home Network? -solved-
nochView
After instalation I canot acces the NAS. The explorer of xnview shows only the computer i am working on in the network. The windows explorer (windows7) works fine and shows all existing network divices. Any help
Thanks
Thanks
nochView
Re: Does it work with my NAS in the Home Network?
problem solved:
I added the button "refresh" in the button bar and pushed the button. Now I can see the NAS and can browse with xnview the hole file system of the NAS.
