Up front, I am sorry, most probably I am overlooking a feature.
I vainly searched for it.
Say, I am running Explorer, have images in thumbnail view.
I select two almost identical images and context menu select "Open with...'> XnViewMP (or hit Enter)
XnViewMP is launched with two tabs.
Then I would now like to have the images side by side so as to better see which one is the best.
Q: How do I accomplish that?
Thanks.
Display images side-by-side
Re: Display images side-by-side
In the browser Tools > Compare... should be what you need, you can display two (or more) images side-by-side.
mrwul
Thanks a lot!
Sadly this isn't available in the Viewer Mode
like compare open files or so.
Meanwhile posted this in the Suggestion section.
Anyway, thanks again.
