xnview MP cannot open .ico and .jfif
mulanee
Post by mulanee »
With xnview MP, I cannot "open with.." some files extensions.
As for now: .ico and .jfif
When I open xnview MP and file/open, it works.
I have not this issue with xnview classic
Emmanuel
Re: xnview MP cannot open .ico and .jfif
if you drag&drop .ico or .jfif on xnviewmp icon, it works?
mulanee
Post by mulanee »
Yes it works.
I installed the latest version.
Still the same behaviour, double clic doesn't open the file, only opening xnviewmp
Emmanuel
you need to check registry entries
mulanee
Post by mulanee »
xnview wrote: Mon Oct 05, 2020 3:18 pm you need to check registry entries
I did it but nothing to learn.
.ico is written to be opened with xnviewmp.
And in fact it is what is happening, except the content of the .ico is not shown:
Emmanuel
if you try to drag&drop a .ico on XnView MP's icon, same thing?
mulanee
Post by mulanee »
You asked already, İ said yes :mrgreen:
Emmanuel
mulanee wrote: Tue Oct 06, 2020 6:47 pm You asked already, İ said yes :mrgreen:
Sorry ;) i've tried with 0.97.0, and i can drag&drop correctly a .ico on XnView MP's icon
mulanee
Post by mulanee »
I am able too
This is not the problem
Emmanuel
if it works, it seems that you have a problem in the associated registry entry
mulanee
Post by mulanee »
xnview wrote: Thu Oct 08, 2020 4:04 pm if it works, it seems that you have a problem in the associated registry entry
Maybe but where?
Nota: even in admin mode, I am not able to change the files association, clicking on the button makes nothing
Emmanuel
mulanee wrote: Thu Oct 08, 2020 7:54 pm
Maybe but where?
which button? Please .ico registry entry
mulanee
Post by mulanee »
Instead of portable version I installed the new release through the installer.
Seems far better then..
Emmanuel
