Compare open files from "Viewer Mode"
mrwul
Post by mrwul »
I'd like to select and open files from Windows Explorer.
Then compare them side by side (same is in Browser Mode).
Suggestion: add Shift-C Compare to Viewer Mode.
Thanks.
(the next day)
Discovered that this has been on the list of 'Differences' (XnView<>XnViewMP) for already quite a while.
Matter, to some extend, solved: I should simply go back to XnView Classic, Windows>Tile vertically.
Re: Compare open files from "Viewer Mode"
Sorry but it's not possible
mrwul
Post by mrwul »
Sad news... :(
XnView has something that is not possible in XnViewMP
Whereas I assumed XnViewMP is the more 'advanced' version of XnView.
mrwul wrote: Fri Oct 16, 2020 9:03 am Sad news... :(
XnView MP is not based on same toolkit, and is not "MDI" based
