Can't run XnView MP 0.97.0 AppImage in POP! OS 20.04
foth
Post by foth »
Hi!
Can't run XnView MP 0.97.0 in POP! OS 20.04:
anton@notebook:~/Downloads$ '/home/anton/Downloads/XnView_MP.glibc2.17-x86_64.AppImage'
qt5ct: using qt5ct plugin
Cannot mix incompatible Qt library (5.12.8) with this library (5.15.1)
Aborted (core dumped)
anton@notebook:~/Downloads$ '/home/anton/Downloads/XnViewMP-linux-x64/XnView/XnView'
/home/anton/Downloads/XnViewMP-linux-x64/XnView/XnView: error while loading shared libraries: libQtAV.so.1: cannot open shared object file: No such file or directory
Re: Can't run XnView MP 0.97.0 AppImage in POP! OS 20.04
which QT version do you have?
foth
Post by foth »
5.15...
foth wrote: Sun Sep 27, 2020 2:52 pm5.15...
i've fixed the package
foth
Post by foth »
thank you! now it works!
Why don't you compile a flatpak? I think this is the standard in the Linux world now.
foth wrote: Mon Sep 28, 2020 12:57 pm thank you! now it works!
i need to check how to build a flatpak package
xnview wrote: Mon Sep 28, 2020 3:37 pm
foth wrote: Mon Sep 28, 2020 12:57 pm Why don't you compile a flatpak? I think this is the standard in the Linux world now.
Building your first Flatpak
How to build a Flatpak
joshas
Post by joshas »
There is a XnViewMP flatpak repository with older version, but it hasn't been updated from last year: https://github.com/flathub/com.xnview.XnViewMP
joshas wrote: Tue Oct 20, 2020 6:11 pm There is a XnViewMP flatpak repository with older version, but it hasn't been updated from last year: https://github.com/flathub/com.xnview.XnViewMP
Exactly, but that version was not created by Pierre I think, probably by Flatpak.org who haven't packaged later XnView MP releases...
joshas
Post by joshas »
I've created a pull request with most recent version of XnViewMP (0.98.2): https://github.com/flathub/com.xnview.XnViewMP/pull/8 .
But there's at least one big issue with this build: directories cannot be deleted, when "Use Recycle Bin" option is enabled. Might be a bug in QT 5.12. Maybe someone more familiar with Flatpak could investigate?
Would be great if author of XnView could take over ownership of flatpak repository to manage releases there. Packaging and testing could be done by community.
