I have a pdf file generated from multiple images. I want to export it into multiple jpg files (or some way to separate the individual pages). All I can get out is the first page. Suggestions?
Thanks
Export multiple pages
Re: Export multiple pages
There is an option in the browser to create a multipage file from individual images, but I don't see an option to extract images from a multipage file, a surprising omission if it hasn't been added yet. Another popular freeware software does have the option.paeyer wrote: Mon Sep 28, 2020 7:15 pm I have a pdf file generated from multiple images. I want to export it into multiple jpg files (or some way to separate the individual pages). All I can get out is the first page. Suggestions?
However, you should be able to do what you want using Tools > Batch convert... by loading the multipage file and suitably configuring the Multipage options on the Output tab. No need to select any Actions, but explore the options on the Output and Settings tabs to avoid surprises!
