The new version did not fix the problem with the high CPU usage when minimized:
High CPU usage persists [Solved]
toyotadesigner
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: High CPU usage persists
it's always after a wake up?
toyotadesigner
Almost. I found out that the CPU usage is not 100% if I have no thumbnail selected.
Just noticed today that it doesn't happen as often with the folder for the new month with only 100 images so far. In the September folder there have been 750 files, some of them rather large with 450 MB per image.
I keep watching it and will post an update if I can gather more facts about the behavior.
toyotadesigner
With the last version the problem is gone.
Thank you very much, I really appreciate it!
