Ghostscript "file can't be loaded"
Buttertea
Post by Buttertea »
XnView MP: Version 0.96.5 64bits (Aug 17 2020)
OS: Windows 10 64bit
PDFs can't be loaded with the newer versions of Ghostscript that I tried: gs9531w64 and gs9533w64.
Effect: Pop up with "File can't be loaded, install Ghostscript"
1. Install GhostScript 9.53.1 or 9.53.3
2. Try to open a PDF
Actual behaviour (bug): it doesn't open the PDF (and probably not the other formats that Ghostscript does either, but I haven't tried those)
Expected behaviour: open the PDF
Note: this does work with Ghostscript 9.50. Uninstall the newer version and install the older version works a treat. But go back to the newer versions and it won't work again. Tried it also on my laptop, same behaviour.
Re: Ghostscript "file can't be loaded"
yes, See issue for current status and some details.
Buttertea
Post by Buttertea »
That was quick :-). Thanks.
