XnView: MP 0.96.5 - 64-bit
OS: Windows 10 - 64-bit
Effect: Shift select not showing correct preview
1. Have a list of images to preview.
2. Select a file halfway down the list.
3. Hold shift and uparrow a few times to select a range of files. As you uparrow the preview pane will show the selected image.
4. Now press down whilst still holding shift, the preview pane will skip back to the first image selected and ignore whichever image you are currently on in the file list.
Actual behaviour (bug): Shows original selected image in preview pane instead of currently selected image.
Expected behaviour: Should show whichever image is currently selected in file list in the preview pane.
In the file list, shift + downarrow, I can go down and select a range of images say image1 - image10 while seeing them in the preview pane then deleting them.
However if I use shift + uparrow something fishy happens.
Say I have image1-20 in file list. I start with image10 selected and displayed in the preview pane, now I hold shift and uparrow to select a range, all is well and the selected image is displayed in preview pane. So I select image10, 9, 8, 7, 6, 5 in that order because I'm working up. Now I have 5 images selected and image 5 is selected in the file list and displayed in the preview pane. However If i now press downarrow while still holding shift I will have 4 images, image10 - image6 selected, image6 is selected in filelist, however it will show image 10 (the image I started my multiple selection with) in the preview pane instead of image6.
So basically if I shift select whilst going down the list it works fine, even if I go back up, displaying the currently selected file list image in the preview pane. However if you go up and then down, as soon as you go down it displays the first image selected instead of the currently selected image in the file list.
Subject: 0.96.5 : Shift select showing wrong image
Greyzier
Re: Subject: 0.96.5 : Shift select showing wrong image
i can't reproduce with lastest version
