XnView: MP 0.97 - 64-bit
OS: Windows 7 - 64-bit
Effect: Filename extension is not the same as the current opened image when executing Save As.
1. Open an image file (PNG)
2. Exec 'Save As'
3. The file type is the last used type (JPG)
Expected behaviour: The default file types should be the same as the opened image when executing Save As.
0.97: Save As...Filename Extension
Re: 0.97: Save As...Filename Extension
'Save as' keep last format used
