IPTC Variable in watermark file path
Erik Bachmann
Post by Erik Bachmann »
On converting my photos to TV format, I insert some info as text and a national flag for origin using watermark.
Can I use the Country code from IPTC as part of the image file name in the watermark?
Can I use a file path as: /Photo/{IPTC:Country Code}.png
Regards {ö} Erik Bachmann
URL: http://ClicketyClick.dk
Re: IPTC Variable in watermark file path
no sorry
Post by michel038 »
By using batch rename ?
Erik Bachmann
michel038 wrote: Mon Oct 12, 2020 1:02 pm By using batch rename ?
No - watermark i batch convert
Erik Bachmann
Tried to filter on "IPTC/Country Code" in search. It seem not possible. I can only filter on "IPTC/Source" and it fails filtering on country code.
The option "IPTC:All Fields" does not have a "Does not contain"
But I can filter foreign countries by "XML:Country" "Does not contains" "Denmark" and "Danmark" - but sure "IPTC:Contry Code" would be more precise.
Btw - There's a typo in "Does not contains"
