relay wrote:XnView: MP 0.97 - 64-bit
OS: Mac OS 10.14.6 - 64-bit
Effect: XnView Memory leak
XnView Memory leak when reading
When reading the new directory to generate preview images, there are more than 500 pictures in HEIC format in the directory. The memory keeps increasing and crashes until the virtual memory is occupied, resulting in insufficient disk space. It should be that the memory is not released when reading the HEIC format images, resulting in memory leakage.
Must exit the program to release the occupied memory, hope to repair as soon as possible, thank you!
0.97: Memory leak
- Forum Librarian
0.97: Memory leak
Originally posted yesterday by user relay:
Re: 0.97: Memory leak
fix in 0.97.1
This problem is supposed to be fixed in XnView MP 0.97.1. Please check and confirm the bug fix here.
