Scrolling in MP
Hans L
Scrolling in MP
Post by Hans L »
I must make an image large to be able to see the content. So, the top, bottom and sides are bleeding. But I cannot scroll. How come?
Thanks!
Hans L
Re: Scrolling in MP
with keys or mouse
Hans L
Re: Scrolling in MP
Post by Hans L »
I was actually thinking scroll bar, but if that is not possible, I'd be grateful for either mouse or keyboard or both.
Hans L
Re: Scrolling in MP
Hans L wrote: Thu Oct 15, 2020 3:02 pm I was actually thinking scroll bar, but if that is not possible, I'd be grateful for either mouse or keyboard or both.
Two scrollbars, one for horizontal and one for vertical movement, would be necessary wouldn't they?
... but if that is not possible, I'd be grateful for either mouse or keyboard or both.
There are already options in Tools > Settings > Interface to scroll using the keyboard or mouse, I'm not sure how satisfactory they would be with an image with large pixel dimensions in the absence of sensitivity settings...
Scrollbars would probably provide the easiest navigation for large images, possibly with an option to enable them, and maybe an option to select whether they should appear automatically when required, some users might not want them taking up screen space. Some though needed.
Hans L
Re: Scrolling in MP
Post by Hans L »
cday, mouse works okay. But keyboard, not.
In one .jpg file, keyboard works okay, in another jpg file, left/right does nothing and up[/down zooms in and out.
Scrollbars is the way to go.
Hans L
