XnViewMP 0.97.1 - use last used directory at startup
masterjp
XnViewMP 0.97.1 ignore this setting. It starts with a blank browser.
mudo_j
Re: XnViewMP 0.97.1 - use last used directory at startup
I can't reproduce this, it works for me. Win10 x64.
masterjp
Now I know the reason for the problem:
I activated a checkbox in settings menue, which clean the file and folder history.
The german translation of this setting entry is not precisely.
It says clean file history after closing xnviewmp.
It although cleans the opened directory history. So it does not work at my computer.
Problem solved.
Problem solved.
If you feel that the German translation is not optimal, you should perhaps report that to Helmut on this thread:masterjp wrote: Fri Oct 16, 2020 3:47 pm I activated a checkbox in settings menu, which clean the file and folder history.
XnView MP - Translation
You can argue the point with him...
masterjp
I write Helmut a message to check it.
