WMF conversion results in bluring
Mike
Post by Mike »
I am converting a WMF to a GIF (although I tried converting to jpeg also) and the resulting image is "blurred". Line edges look bad, and text looks really bad. Here is the command I am using: nconvert -out gif -colors 256 *.wmf. I can see the original WMF in Word and it looks very sharp, but the resulting gif is garbage. What can you suggest?
Mike
Post by Mike »
Actually, I have pinned this down to using the resize option. Any thoughts as to how to resize without loss of quality would be appreciated.
Re: WMF conversion results in bluring
Mike wrote:Actually, I have pinned this down to using the resize option. Any thoughts as to how to resize without loss of quality would be appreciated.
Currently there is no option to set output size for WMF...
Mik
Post by Mik »
Actually, I am having the same issue when converting from JPEG to GIF. When I use the resize option, the image pixelates.
Thoughts?
Mik wrote:Actually, I am having the same issue when converting from JPEG to GIF. When I use the resize option, the image pixelates.
Thoughts?
Which command line do you use?
Mike
Post by Mike »
Mike wrote:nconvert -out gif -colors 256 -resize 300 300 *.jpg
Please put -resize before -colors
Mike
Post by Mike »
That did it. Thanks. :D Probably could do well to document that.
