I am referring to this topic: viewtopic.php?f=62&t=40980
Today I had the high CPU usage problem again after waking up my iMac. I left XnView MP with a thumbnail list from last month.
Because it had even less files than before after I deleted hundreds of »work in progress images«, I could not spot any significant difference to the thumbnails in this months folder — except for one single *.svg file.
So I moved the *.svg file out of the thumbnail list and placed it on the desktop, leaving XnView MP again with the thumbnail list from last month, sending the iMac into »Sleep« for several hours. After waking the machine up again, the problem with the high CPU usage was gone.
I have sent the iMac several times into Sleep and woke him up after a while — no high CPU usage again.
Could it be that the *.svg file format caused the problem?
If you need the *.svg file, I will mail it to you because it should not be published anywhere. Thanks!
High CPU usage again + bug probably found
toyotadesigner
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: High CPU usage again + bug probably found
if you move the svg files in another folder, and going on it with XnView MP, and going in sleep mode, same problem?
toyotadesigner
Haven't tried it, will test it tomorrow.
toyotadesigner
I've placed the *.svg file into another folder and left it open before I sent the Mac to sleep. This morning after waking the Mac up I had another high CPU usage. Deleted the file from the folder, switched to another folder and back, the high CPU usage was gone.
is it possible to have the svg files?toyotadesigner wrote: Mon Oct 26, 2020 6:03 am I've placed the *.svg file into another folder and left it open before I sent the Mac to sleep. This morning after waking the Mac up I had another high CPU usage. Deleted the file from the folder, switched to another folder and back, the high CPU usage was gone.
toyotadesigner
Yes, where do you want me to send it?
you can on contact @ xnview . com
toyotadesigner
Thanks, it is on the way to you.
