One last thing that's also related with the previous is if there's any way to move a picture that's bigger than the screen resolution so that we can see all of if with a "grab and move" feature or something. the closest i get is using the mouse buttons to move it horizontally, but it's way much slower.
thanks in advance.
congratulations for the great work on this software.
Viewing large images
Re: Quitting Fullscreen mode, Viewing large image
With the right mouse button you can grab the image and move it (think you knew).|VooDoo| wrote:...One last thing that's also related with the previous is if there's any way to move a picture that's bigger than the screen resolution so that we can see all of if with a "grab and move" feature or something. the closest i get is using the mouse buttons to move it horizontally, but it's way much slower.
For vertical scrolling in an image via keyboard, you can use the "Cursor up/Cursor down" keys. If you want to scroll in images horizontally using the keyboard, you can set the option "Cursor Left/Right" to "Scroll left/right" (in Options dialog "View->Keyboard/Mouse"). Once you have set this, you can fully navigate in the image using the cursor keys.
For navigating to the next/previous image, you then have to use the "Page up/Page down" keys.
VuDu
Doolittle
I stumbled on this same problem. Not being able to use the mouse to move a large image (larger than the visible screen) in fullscreen mode is a bad thing, with all those huge digital photo's that are produced by todays digicams. Otherwise, nice and fast program, but this is a point that needs to be addressed (and could be easily I guess, though I'm not a programmer).
