Cycling after Saving Cropped image
harrygeier
Post by harrygeier »
When i have a long list of pictures in a folder, starting with a image on top of the list, if i do like :
Crop a part of the image and save it under a new name
It puts the image at the BOTTOM of the list and i need to cycle up to the original image again to continue thru the list.
I trieds all sorts of setting..sometimes i think it works properly...next moment it works "buggy" . I think the list order should not change, so if i edited pic035 it should bring pic036 on cyling down, not the new and last image in folder, or at least resort because then pic035_1 ( saved crop ) would be next and then pic036 . This is what happens after going back to list and resorting on name.
Re: Cycling after Saving Cropped image
you would like that new image file is sorted correctly?
