It's possible to customize the main toolbar. That's good. But I can't customize the browser toolbar in the same way.
The way I'm used to using the program (or rather, these kind of image viewers) is to have a narrow column that is the browser, and ALL the rest of the program's screen real estate is to see the image. It's basically "Viewer" mode but with a browser glued to it.
Anyway, this makes the browser toolbar a bit unwieldy. At the very least there are two textboxes and a big trackbar. I would like to reduce that to only the directory textbox, and view mode button. That's all I need there.
Customize browser toolbar
Using Windows 10 20H2 and loving it. Cheers!
