I'm wondering about the fact that the slideshow starts always from the end (this means if I mark the sorted pictures the slidshow didn't start with the first picture. Instead of this the slideshow starts always from the last picutre in direction to the first picture)
Is here any way to start a slideshow with the "first" selected picutre?
(64-bit Windows 7 Pro / XnView MP Version 0.97.1)
best regards
Enrico
Slideshow starts from the end [Solved]
Re: slideshow starts from the end
Please check the order of the filelist
Enrico_xyz
The sorting / naming of the files is correct.
For exmale: I select the file 1 to 10 => the slideshow starts always with the last file and with the arrow key "right" I can move change from 10 => 9 => 8 ...
I've tested this behaviour with serval different files. It's curious why this is interverted
You can click in the header of the column in the file list (1st tab in slideshow window) : this reverses the order (by name, size, date ...)
Catalogage avec XnviewMP :
If file list you have the correct order, and slideshow starts from the end?Enrico_xyz wrote: Sat Nov 21, 2020 4:06 pm The sorting / naming of the files is correct.
Enrico_xyz
Grest. Many thanks for this hint. I was able to correct the sorting (1st tab in slideshow window => change to "list view" => correct sorting)michel038 wrote: Sat Nov 21, 2020 5:55 pm You can click in the header of the column in the file list (1st tab in slideshow window) : this reverses the order (by name, size, date ...)
btw: Is any change to start the slideshow automatically from my 2nd screen?
