I'm resurrecting this old thread, but last weeks I have great troubles with *xcf files. XnView crashes each time it tries to generate thumbnail and it does not render preview. I think the case is with layers and rgb, 16 bits channels. I'm not sure however. I applied also custom filter and added no thumbnails for xcf files under (Video -> Other).
XnView MP Windows
Version 0.94.2 64bits (Dec 20 2019)
Libformat version 7.36
Gimp 2.10.22
2.39: Gimp-made images crash XnView
Re: 2.39: Gimp-made images crash XnView
ryobg
Heya,
there you go. It is just simple 16-bit PNG grayscale with one layer.
https://www.dropbox.com/s/iw33pbfd6p84l6o/tmp.xcf?dl=0
Let me know whether you have downloaded and can reproduce this issue.
if you have only this file in a folder, you have a crash?
ryobg
Aww... I expected an email notification when replied to.
But yes, I do. If that some help, look at this:
