b1: Lossless crop keys unavailable
Locked
marsh
Post by marsh »
According to change log:
ctrl+shift+y is now lossless crop- but standard crop is still using this shortcut. It should also be added to tools> jpg lossless transformations menu in some future version.
Re: beta1: Lossless crop keys unavailable
marsh wrote:According to change log:
Right so Ctrl+Y => Crop, Ctrl+Shift+Y => Lossless crop
Dreamer
Post by Dreamer »
Yes, "Ctrl+Shift+<x>" is used also for other lossless operations (rotate).
Minor - Standard Crop should be also in menu > Image > - now, just auto-crop is there.
Hum, are you use, crop is in Edit menu
marsh
Post by marsh »
Fixed in beta 2. ctrl+shift+y is now lossless crop, it works well for me.
Xyzzy
Post by Xyzzy »
Fixed in b2.
In b1 Ctrl+Shift+Y just crops image, in b2 there is warning about lossless transformation modyfying original image, so I guess it is fixed.
X.
Locked
