XnViewMP - similar files - comparing starts with step 2/2
masterjp
Post by masterjp »
I started a similar file search today and was a little bit suprised, that the process starts with step 2 of 2.
After step 2 XnViewMP need a further step to search similar files. So I think the step proccess directly starts with 2 and not with 1.
Re: XnViewMP - similar files - comparing starts with step 2/2
Step 1 search folders, Step 2 search all files
masterjp
Post by masterjp »
Okay, then I understand, why I do not see step 1.
But the progress bar of 'step 2' takes 2 times!
masterjp wrote: Fri Nov 27, 2020 8:13 am Okay, then I understand, why I do not see step 1.
Step 1 can be quick :)
