Hello XnView team and board,
first of all: I love XnView (MP), thanks for this awesome program!
My question is about preversing the rating in *.png files.
When I rate *.png images, the rating appears in XnViewMP.
Now I use Photoshop (PS) to view the rating and it's not there.
When I change the rating in XnViewMP and save the file (viewer mode), the rating appears in PS.
First problem:
I want to rate the files in Browser mode, but there is no "File/Save" option.
Second problem:
I want to rate the pictures fast. I don't want to save every single picture manually.
Any suggestions how to fix my problems?
Here are my metadata settings:
Option to write the rating automatically in *.png [Solved]
quallip
Re: Option to write the rating automatically in *.png
by using 'Export DB Category...' the rating is saved in PNG, coulmd you send me your image file?
quallip
Thanks for your reply.
I found out that Photoshop was the problem.
The metadata was written correctly by XnView.
