0.97.1 Canvas resize background color Alpha is ignored?
hexaae
Post by hexaae »
XnView: MP 0.97.1 - 64 bit/64 bit
OS: Windows 10 20H2 64bit
Canvas resize, background color Alpha is ignored...
Effect: program always uses Alpha 255 for background color
1. Convert series a pic
2. add as Actions: Resize Canvas and choose a background color + alpha level (e.g alpha=0)
Actual behaviour (bug): preview and final result will always be processed as Alpha=255 :bug:
Expected behaviour: preview and final conversion should use user defined color + alpha
Re: 0.97.1 Canvas resize background color Alpha is ignored?
you need to insert before 'canvas resize' a 'change color depth' 32bits
hexaae
Post by hexaae »
Uh, ok... is working now! Thank you
Gavlan7
Post by Gavlan7 »
Removing the background from a picture is relatively easy if you upload it to a site that does it fast and easy for you. Then, of course, you should look for a decent one since many of them are click baits. I don't even count the times that I have looked for a simple program like this and end up with sites asking for money, or the links are just a waste of time. If you are looking for a way to remove image background, then one of the best sources I can advise is BG remover. It's the only program that I was able to use without deteriorating the quality of the photo.
