This is my first post here!
I have installed XnViewMP but I cannot see a way to upload images to Flickr. Is this possible?
David Green
Upload images to Flickr
Re: Upload images to Flickr
Judging by the silence on this question, I assume Flickr upload is NOT supported.
I have not seen any internal tools that support uploading to anywhere in the program
There IS an "Upload t Web" feature but it does not include Flickr
I would suggest the zoom uploader which I use daily. It supports Fickr and about everything else. Free but if you donate a few bucks you can use your account logins etc. IF Flickr or anyone changes their formats, he is quick to fix it. as well as add new sites
http://z-o-o-m.eu
Try it
http://z-o-o-m.eu
Try it
Rick
Rick
