b1: Autocollapse function doesn't work properly
klumy
Post by klumy »
sometimes it works sometimes not.
XnView 1.82 <x>
XNView 1.91.5
Windows XP SP3
Re: Beta1 Bug: Autocollapse function doesn't work properly
klumy wrote:sometimes it works sometimes not.
Do you have a way to reproduce it?
klumy
Post by klumy »
currently it doesn't work at all :(
XNView 1.91.5
Windows XP SP3
klumy wrote:currently it doesn't work at all :(
Old selection is never collapse?
klumy
Post by klumy »
no, maybe someone else can check if this feature work under Windows 2000 SP4
XNView 1.91.5
Windows XP SP3
ckit
Post by ckit »
I can confirm this bug as well.
ckit wrote:I can confirm this bug as well.
But how to reproduce it, on my 2000, it works :-(
ckit
Post by ckit »
I can reproduce it 50% of the time.
As Klummy first posted, sometimes it works and sometimes it doesn't.
Xyzzy
Post by Xyzzy »
And it is supposed to do what?
X.
klumy
Post by klumy »
Xyzzy wrote:And it is supposed to do what?
X.
you can find a similar function in the internet explorer in the favourites menu. unused folders will be auto. collapsed
XNView 1.91.5
Windows XP SP3
marsh
Post by marsh »
klumy wrote:no, maybe someone else can check if this feature work under Windows 2000 SP4
It works at a limited directory depth. Which means if you open another on same level ex. c:\test it will close again on opening c:\gif. However, if you open c:\test\subfolder and then open c:\gif, only child folder closes and not the parent c:\test folder as well.
Yes i close the parent of previous selection, must i collapse the full branch??
klumy
Post by klumy »
yes please,
this would be great
XNView 1.91.5
Windows XP SP3
Xyzzy
Post by Xyzzy »
I second that. IMO this option should keep the minimally expanded tree, so that tree is kept minimal when fe. jumping around with favourites.
X.
Xyzzy
Post by Xyzzy »
Now works OK, I have only a small proposal:
If it is technically possible, delay folding tree until another branch is expanded (not selected).
Reason:
'Single click to expand folder tree' is UNchecked.
I browse c: drive. Now I would like to browse e: drive. I click e: drive (it is now selected, but not yet expanded), then c: drive folds and my e: drive escapes up. I have to move mouse up to complete expanding branch.
X.
