Remember last selected Image in every folder
fishmi
Post by fishmi »
Please "remember" the currently select images in each folder as I move back and forth.
This would be such a time saver!
If you don't need this, you should be able to disable it in the settings.
Thanks
fgordona
Re: Remember last selected Image in every folder
Post by fgordona »
Yes, this! You beat me to it by 3 years :)
It would be such a great time and nerves saver. It's very annoying to have to scroll through hundreds of thumbnails to search for the last one that you were using when having to switch back and forth between folders.
If it could remember at least for the current session it would be very helpful. And, to avoid memory problems, maybe limit the size to some decent number, like 1000 or something.
Tekaiguy
Post by Tekaiguy »
+1 I was going to make a new request for this feature but now I don't have to.
hawaii
Post by hawaii »
agree
