Hi there,
Quite often I have to add GPS data to older pictures and I use Google Maps as input for that. Unfortunately Google presents the coordinates with a decimal point and not with a decimal comma and so copy and paste does not work due to the format restriction in the GPS dialog.
it would be great if it were possible to add support for a point as the decimal delimiter in the GPS dialog.
Regards
Thomas
GPS: Support for point in coordinates
Re: GPS: Support for point in coordinates
hi,
Since V0.96, it works automatically for decimal coordinates.
Simply copy the coordinates from google maps, and use the "paste" button on xnviewmp...
(I am also waiting for a further version of the free software PicaGeotag to generate gpx tracks, and geotag photos where the positions will be estimated from their timestamp)
Catalogage avec XnviewMP :
