Drag & Drop to other Applikations doesn't work since last update
afphoto
Post by afphoto »
Hi, I installed last update XnView MP Windows
Version 0.98.0 64bits (Dec 14 2020) Libformat version 7.64 and since then I can't drag and drop pictures into other applications any more. This is a real problem. It only works to double click one picture and copy and paste into other application. But this workaround doesn't work with more than one pictures. I hope you can Fix this problem. It makes working with XnView impossible for me. I'll try to install old version and hope this is possible.
XnView is really the best software of its kind. Thanks
Re: Drag & Drop to other Applikations doesn't work since last update
i can't reproduce, which other applications?
