0.98 Regression; Dropdowns missing from Favorites folder
Rick
Post by Rick »
Subject: 0.98:Regression; Dropdowns missing from Favorites folder
XnView: MP 0.0.98 64 bit
Windows 10 x64
Dropdown arrows missing from Favorited folders
Effect:Formerly we had dropdown arrows on the favorites foldes making navigation more robust
Actual behaviour (bug): Since 0.98 there are no longer dorpdown arrows to access folders below a Favoritd :bug:
Expected behaviour: The arrows have previously been there so one could access the folders under a particular Favorite
Rick
Re: 0.98 Regression; Dropdowns missing from Favorites folder
It's not a regression but a change
You can change
favShowFiles=true
Rick
Post by Rick »
Thanks. I made the change in the INI file
Will it be in settings at some point so it may be more easily changed? Or possibly documented somewhere?
Anyway, thanks again, I have it fixed
Rick
