Try the new "Random file" navigation! :)
winnylinny
Post by winnylinny »
Everyone, 0.98.0 is a fantastic release! Try out the new "Random File" feature! :mrgreen:
Go to Tools > Settings > Interface > Shortcuts > Viewer mode > Random file > Shortcut for selected action > Custom
Assign it the custom keyboard shortcut: 0 ("zero" on your NumPad).
Now when you are viewing images with the Viewer, you can use:
  • Left Arrow to view previous image
  • Right Arrow to view next image
  • 0 to view random image
Since the "0" key is next to the arrow keys on most keyboards, this makes it convenient and easy to use! Try it out yourselves, I think you'll like it!
If you bump into any bugs or strange behavior, please share it. This is still a very new feature for XnViewMP.
jpvdmeij
Re: Try the new "Random file" navigation! :)
Post by jpvdmeij »
XnViewMP is the best! Where all other viewers I have tried have great difficulties loading large directories, XnViewMP outperforms all of them.
E.g., I have some directories with >70000 images and they load quite well.
On topic to the random file feature: this is really great! But I have noticed some 'strange' behavior: the random index that is generated has a limitation. In these large directories, it doesn't seem to ever select a file with index > 32000 or so. This happens both when using the keyboard and when using a random slide show.
Such number rings a bell: to me it looks like the number generated is a 16-bit signed integer, which has a maximum value of 32767.
I am using v1.4.2. A fix for this would make XnViewMP even more awesome!
