Windows 10 Pro 64-bit, XnView MP v0.98.0 64-bit
Current behavior:
XnView MP adds several spaces to the filename in the info display when the filename contains at least one space character.
How to reproduce:
1. Enable display of image information (Settings > View > Info)
2. Open an image file, with the filename containing at least one space character, either in Fullscreen or View mode
3. The info adds trailing spaces to the filename (example images attached below)
Expected behavior:
The info display should not add any trailing spaces to filenames containing space characters.
0.98.0: Incorrect display of filenames containing space character
deus-ex
Re: 0.98.0: Incorrect display of filenames containing space character
if you disable 'HTML Tags'?
deus-ex
Confirmed, with "HTML tags supported" disabled there are no trailing spaces shown. Is it intended to work that way?
No, but i have a problem with the HTML enginedeus-ex wrote: Wed Dec 23, 2020 4:31 pm Confirmed, with "HTML tags supported" disabled there are no trailing spaces shown. Is it intended to work that way?
