b1: compare window: deleted picture is not closed
Locked
FlorianH_
Post by FlorianH_ »
If I delete (not close) a picture in the compare window, the picture isn't closed but still visible. :bug:
If there are only two pictures in compare window and I close one, the compare window should be closed...
Re: compare window: deleted picture is not closed
FlorianH wrote:If I delete (not close) a picture in the compare window, the picture isn't closed but still visible. :bug:
But you have the same problem if you have 3 or 4 pictures.
Do you think that after a delete, i must remove (or close) the view of picture deleted?
FlorianH
Post by FlorianH »
I'm not sure, if we're talking about the same...
a) If I opened compare with two pictures and I decide to delete one of them (because it's worse than the other and I want to keep only one of the two), you should close the compare window because I'm finished with comparing.
b) If I open compare with e.g. three (or four) pictures and I delete one of them, you should close the view of the deleted picture (it's not usefull anymore, because the picture is already deleted) and you should rearrange the two (three) pictures to best use the available screen space.
You know what I mean?
FlorianH wrote:I'm not sure, if we're talking about the same...
Yes it's that, but it's not the current behaviour for 2, 3 or 4 pictures :-)
Dreamer
Post by Dreamer »
Yes, 2 bugs for me. When I delete something, it should be removed from screen.
Confirmed.
But closing "Compare" window if there is only one image left works for me.
FlorianH
Post by FlorianH »
helmut wrote:...
Yes, it works if you close the last but one. It doesn't work if you delete it.
FlorianH wrote:
helmut wrote:...
Right. (I think this is due to the fact that deleted images are never closed).
Dreamer
Post by Dreamer »
Fixed.
Locked
