Convert color profile?
marianillo
Post by marianillo »
I'm new to XnViewMP, and I find that it's a great piece of software for my needs... except it lacks one critical thing: I need to be able to convert pictures to the sRGB color space and embed it on the edited picture.
I have been looking in the program and searching the forum (and on internet), but I haven't been able to find anything about it.
My question is wether is it possible to convert a picture to another color profile within XnViewerMP. If it is, could someone help me find the way?
If not, is it something that is being planned?
Thank you very much for your help!
Marc
PS: As a workaround, I tried XnConvert using the action "ICC convert", but I didn't get the results I expected (the resulting picture didn't have the sRGB profile embedded).
These are the options I used:
- I leave blank the input profile dialog
- I connect the output profile dialog to the sRGB.icm file on my Colorsync library.
- I CHECK the "Ignore embedded profile".
Any thoughts/tips on this?
marianillo
Re: Convert color profile?
Hi again,
Just to say that I managed make XnConvert work to embed the sRGB profile. I just needed to check the right adjustments in the output tab...
zentsang
Post by zentsang »
I know this post is 4 years old, but you didn't say how you resolved your issue. You just say you made some adjustment in the Output tab. Can you share exactly what you did? I've been trying to figure out what I'm doing wrong.
