Hi, I just have one quick question,
Is there any way to use the "quick search" bar to search XMP subject?
I know the Ctrl+F menu has an option for that, but is there a way to get the quick search to do that as well?
It currently can search for IPTC tags, but PNG doesn't support that.
I am currently not using the catalog because it crashes (I have submitted bug reports about that before) and I am using a program to automatically tag images.
Thanks!
Quick Search XMP Subject
Re: Quick Search XMP Subject
sorry but currently no way
winterNebs
Could this be considered for a future update? Being able to automatically tag images is quite amazing, would love to be able to use xnview with this feature!
yes i'll checkwinterNebs wrote: Tue Jan 05, 2021 8:23 pm Could this be considered for a future update? Being able to automatically tag images is quite amazing, would love to be able to use xnview with this feature!![]()
