Updating catalog after installation gives "error 13"
weyb
Post by weyb »
I didn't find any post about "error 13", so I'm creating a new one.
I just downloaded XnView MP 0.98.0 64bits, and when i started it after installation, i had a window asking me if i wanted to update the catalog.
I can answer "yes" or "no", but each time i have the error 13:
"a problem occurred when updating the catalog (error 13), please contact the developer"
(translated from french)
Thank you very much in advance for your help,
Regards
Re: Updating catalog after installation gives "error 13"
you had a very old version of catalog, please remove xnview.db
weyb
Post by weyb »
hi,
where can i find it please ?
nothing found in c:\pgm files\xnviewMP, so I looked for this file in the whole C:\ without success :-(
regards
xnview wrote: Thu Jan 14, 2021 8:44 am you had a very old version of catalog, please remove xnview.db
weyb wrote: Thu Jan 14, 2021 9:41 pm where can i find it please ?
Tools > Settings > Integration -- Paths
Outils > Paramètres... > Intégration -- Chemins :D
weyb
Post by weyb »
like I said int 1st post, I can't launch xnviewMP so i can't access to the menus...
you have it in c:\Users\...\AppData\Roaming\XnViewMP
weyb
Post by weyb »
hello !
thank you very much !!! it worked !
regards
