b1: comments not displayed in browser
Locked
FlorianH
Post by FlorianH »
The comment of a jpeg is not displayed in browser mode (affected views: details, thumbnails & details).
BTW: I can't add comments/description at options->browser->thumbnail->labels. Is there any reason/is it intended like that?
Xyzzy
Post by Xyzzy »
No confirmation. Comment added with XnView Edit->Edit comment is fe. displayed is status bar, if Browser->Info in status bar set to Comment.
Edit: Sorry, I misunderstood problem. Now I can confirm.
X.
Re: beta 1 bug: comments not displayed in browser
FlorianH wrote:The comment of a jpeg is not displayed in browser mode (affected views: details, thumbnails & details).
Right i confirm
Often comment or description are long, so too long for the label. Is it needed??
FlorianH
Post by FlorianH »
xnview wrote:
FlorianH wrote:BTW: I can't add comments/description at options->browser->thumbnail->labels. Is there any reason/is it intended like that?
It's possible to use IPTC.Caption and this field is for the same purpose (isn't it?). Right now, you simply cut the text if it's too long. Perhaps you better use ellipses (...), so the user knows, that the text is cut.
Ok, i'll comment in label list
Xyzzy
Post by Xyzzy »
b2, deleted .ini
Now there are 2 items for EXIF: Comment (last and 6th from the end) after adding them to displayed labels, after reopening Options dialog EXIF: Comment ist still avaliable in the left list.
I added Comment (not Description) to JPEG file with no EXIF. Now the comment is displayed in status bar, but there is no EXIF in image?!?
Status bar is not updated after changing Comment in browser.
Comment is still not displayed on label (also for image with proper EXIF).
X.
Xyzzy wrote:b2, deleted .ini
Right i'll add 2 user comment :-)
If you have a picture with user comment not shown, could you send me it?
Xyzzy
Post by Xyzzy »
Wait a second, I think I am lost: there is description, IPTC Comment, EXIF Comment and ANOTHER comment? Where is it stored???
X.
Description--- ?
:) Hello L. !
- In a descript.ion file ? :D
:mrgreen: Kind regards,
Xyzzy
Post by Xyzzy »
Descriptions (Edit>Describe) are stored in descript.ion. And Edit>Metadata>Set comment????
X.
Xyzzy
Post by Xyzzy »
b3, Comment can now be added as Label and is visible in Thumbnails&Details
Oh, BTW, I guess that THIS comment is written into header of JPG file.
Solved.
X.
Locked
