appimage 0.94.1 - fail to load - Fedora 30 - symbol lookup error
Sprintdriver
Post by Sprintdriver »
Hi.
Latest appimage won't run on Fedora 30, Cinnamon.
Appimage for XnView 0.93.1 works perfectly.
Message from Terminal window
[sprinterdriver@localhost appimages]$ ./XnView_MP.glibc2.17-x86_64.AppImage
/tmp/.mount_XnViewjthXDA/usr/XnView/XnView: symbol lookup error: /lib64/libkrb5.so.3: undefined symbol: krb5int_push_fscreatecon_for, version krb5support_0_MIT
inxi -Fxmz
System:
  Kernel: 5.6.13-100.fc30.x86_64 x86_64 bits: 64 compiler: gcc v: 9.3.1
  Desktop: Cinnamon 4.4.8 Distro: Fedora release 30 (Thirty)
Machine:
  Type: Desktop System: Dell product: OptiPlex 780 v: N/A serial: <filter>
  Mobo: Dell model: 0C27VV v: A01 serial: <filter> BIOS: Dell v: A15
  date: 08/06/2013
Memory:
  RAM: total: 3.68 GiB used: 1.25 GiB (34.1%)
  RAM Report:
  permissions: Unable to run dmidecode. Root privileges required.
CPU:
  Topology: Dual Core model: Intel Core2 Duo E8400 bits: 64 type: MCP
  arch: Penryn rev: A L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 11969
  Speed: 1995 MHz min/max: 2000/3000 MHz Core speeds (MHz): 1: 1995 2: 1995
Graphics:
  Device-1: Intel 4 Series Integrated Graphics vendor: Dell driver: i915
  v: kernel bus ID: 00:02.0
  Display: x11 server: Fedora Project X.org 1.20.6 driver: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Q45/Q43 v: 2.1 Mesa 19.1.8
  direct render: Yes
Audio:
  Device-1: Intel 82801JD/DO HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.6.13-100.fc30.x86_64
Network:
  Device-1: Intel 82567LM-3 Gigabit Network vendor: Dell driver: e1000e
  v: 3.2.6-k port: ece0 bus ID: 00:19.0
  IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
Is there a workaround for this?
Re: appimage 0.94.1 - fail to load - Fedora 30 - symbol lookup error
Sprintdriver wrote: Wed Jan 13, 2021 5:56 pm
Appimage for XnView 0.93.1 works perfectly... ?
The latest Appimages version is 0.98.0, I've just downloaded it from the MP - General Support link to check, and it opens as such in Linux Mint Cinnamon 19.3...
Did you download from somewhere else?
you need to install libkrb5 or check the link
