0.98: Crop load preset is not correct
Mapaler
Post by Mapaler »
XnView: MP 0.98 - 64 bit
OS: Windows 10 64bit
Load preset in Crop is not correct.
Effect: Is forced to be set to a vertical scale
  1. Add a new pair of fixed but opposite pixel croppings.
  2. Select two crop presets separately
  3. The vertical ratio is right.
  4. Actual behaviour (bug): the horizontal ratio is wrong :bug:
Expected behaviour: Produces a wide crop box
Re: 0.98: Crop load preset is not correct
sorry but i can't reproduce, which image size has the loaded image?
Mapaler
Post by Mapaler »
xnview wrote: Mon Jan 18, 2021 3:40 pm sorry but i can't reproduce, which image size has the loaded image?
I unzips a new XnViewMP, and try to re-solve the problem.
I find the proportions strangely present.
specified ratio
  1. When I select the specified ratio that width > height. such as 16:9.
    • If the picture width > height, the crop box is horizontal.
    • If the picture width < height, the crop box is vertical
  2. And I create a new specified ratio that width < height. such as 9:16.
  3. The landscape picture scale is correct, and the portrait picture scale is wrong.:bug:
Specify pixels or print sizes(inch, cm)
  1. It's different from the scale, crop ratio are not affected, whether they are landscape or portrait.
  2. Create two new pixel crop preset, and one is width > height and another one is width < height.
  3. If I chose 100×300, crop correctly.
  4. If I chose 300×100, the ratio is transposed and the preset height is used as the width. :bug:
