Hello!
What do the following options do?
View->Adjust zoom if X/Y DPI are different
View->Fullscreen->Hide play bar
View->Fullscreen->Dual monitor, Stretch over all monitors
View->Fullscreen->Dual monitor, Use second monitor (Browser only)
Slide Show->Center window
Read->Use EXIF DPI information if exists
Thank you.
X.
P.S. Yes, I've searched the forums.
A few simple questions
Re: A few simple questions
Sometimes (fax) have different dpi for each dimension, so this option can rescale picture using these valueXyzzy wrote:View->Adjust zoom if X/Y DPI are different
Hide video play bar in fullscreenXyzzy wrote:View->Fullscreen->Hide play bar
With dual monitor, stretch the picture over the monitorsXyzzy wrote:View->Fullscreen->Dual monitor, Stretch over all monitors
With dual monitor, fullscreen is shown on the second monitorXyzzy wrote:View->Fullscreen->Dual monitor, Use second monitor (Browser only)
Used when you are not iin fullscreen to center the windowXyzzy wrote:Slide Show->Center window
Jpeg file have own DPI information, and in EXIF metadata you have too DPI information. And sometimes, the 2 values are different.Xyzzy wrote:Read->Use EXIF DPI information if exists
