0.98: Unexpected metadata in change timestamp
Mapaler
Post by Mapaler »
XnView: MP 0.98 - 64 bit
OS: Windows 10 64bit
Change timestamp, unexpected metadata is created.
Effect: unexpected metadata
  • Here are 3 jpgs without metadata
  • Change the file time
  • Correct
  • Change file time and Exif time
  • It seems to be right
  • Uncheck Create Exif
  • An additional Exif was added :bug:
Expected behaviour:
If Uncheck Create Exif but Check Exif Date:
The Exif time to modify when a file has Exif;
No Exif is added when a file does not have exif.
Re: 0.98: Unexpected metadata in change timestamp
are you able to reproduce it with latest version?
